Captain Haddock
Chaps,
I wonder if someone can help. I fitted a NASA SX 35 VHF to my boat today and could not get the Garmin 276 GPS to pass it's NMEA info to the VHF.
Here's what I've done:-
1) Established the radio was recieving power and was working.
2) Connected the Blue Garmin NMEA+ wire to the Brown NASA wire.
3) Connected the Black Garmin Negative wire to the NASA Red wire.
4) Configured the GPS COM1 to talk NMEA IN/NMEA OUT @ 4800
5) Set the NASA SX 35 to recieve NMEA data.
With that lot I should be good to go!... not so.
There are a couple of factors that may be causing the problem.
As I was in a boat shed, in my boat I could not acquire a satelite signal, would that mean that because I couldn't acquire a sat link the NASA would still display 999,99,99N, 999,99,99W?
Because of the lack of signal I thought I'd run the GPS in simulation mode, it didn't work. Does simulated mode transmit the simulated data to any NMEA connected device?
And finally...
My boat batteries are seriously low on power, even though I can fire up the radio and the GPS I reckon they are 20% full (The shed has meant no solar top ups). As a result the 276 GPS has an inbuilt battery that lasts for 15 hours, this is fully charged. Could low yacht battery power to the radio be a contributing factor to the NMEA data not being transmitted?
I hope someone can help as this has me baffled, as I'm sure it's wired up right.
And finally...
