garmin 100 fishfinder
gjgm
14 Mar 2002
London
Due to some overfancy electronics playing up, among other things I ve lost my depth sounder. Until it (eventually) is all back to normal, I was thinking of fitting the above, as a cheaper solution to losing the bottom of my hull. I guess I can disconnect the present transducer, and fit the new one next to it, as a good location guide for mounting. Some postings say use silicon ? And I assume it does work on a sportboat on the plane ? Any help or input much appreciated
longjohnsilver
30 May 2001
Silicon definitely works, wot I like about it is you can move it in the future should you so wish, bit more difficult with epoxy!
Renegade_Master
27 Jan 2003
Spain
My Garmin 160 FF came with a transom mounted transducer, but apparantly that was only for stern drives, mine had shafts so had to get the through hull type fwd of the props.
<hr width=100% size=1><A target="_blank" HREF=http://www.suncoastmarine.co.uk>Sun Coast Sea School & Charter</A>
Steve_D
14 Feb 2002
Guernsey
we've got the garmin 100 fishfinder, I poxied ours 'bout 2ft forward of the transom or thereabouts and it works fine up on the plane. The trace is as noisy as hell but the depth shown is about right.
The transducer was the standard one that came out the box.
Regards
Steve D
<hr width=100% size=1>Now I've got to think of another sig....
