Neeves
Does the Zn-Fe intermetallic produce the same cathodic protection that zinc does?[/QUOTE]
Based on it not rusting, yes.
I've been using it for 15 months, obviously in seawater, its either in the sea or in our anchor locker all the time and there is no sign of rust. On that basis it works. I have not been especially looking after it - we wash with seawater on retrieval, the anchor locker can be warm (today its 27 degrees outside
) but the anchor locker drains very well.
The proof is in its longevity, rather than the immediate result. I ran a whole series of abrasion tests, on the seabed, and the claims that the Armorgalv coating is more abrasion resistant than HDG stand up - but to ensure longevity you need a decent thickness - which I put at 100 microns (vs the US Navy/Army at 70-80 microns). My coating is 100/110 microns over a 75 metre length (and I had some connectors coated at the same time) so I achieved what I thought was adequate. Some chain coated previously with much thinner coating thickness, maybe 20 micron, was a major disappointment.
Based on my success someone else is looking at making 8mm x 100m (+15m for a second rode with nylon) of HT, probably G100 (it seems a better option than my G80) it will be stronger, by about 10% than Maggi's G70, 20% cheaper and should last longer. Initial tests suggest it is possible, in the fullness of time, to recoat without any loss of strength.
Jonathan
Jonathan
