MM5AHO
Speaking as a galvanizer....
As has been said, beware electroplated zinc. It's likely to have about 5 microns of zinc versus about 50 on hot dip galvanized.
And then there's centrifuge hot dip and non-centrifuged materials. The difference again is thickness of zinc.
Generally the life expectancy is proportional to thickness of zinc.
As to threaded rod versus bolts: If you cut the end of threaded rod to get length right, you'll have a steel exposed end. While there'll be some protection from circumferential zinc, in a marine environment this might not be enough.
Threaded rod is almost certain to be centrifuged.
Bolts also likely to be, but if you buy black steel (uncoated) then get them galvanized without centrifuging, and then use a die nut to remove surplus zinc that will block the threads, you'll have the thickest galvanizing normally available. If you don't get galvanizing done much, give these to a friendly fabricator to gain from their buying power and to avoid minimum changes.
