VicS
>This (as usual) is absolute nonsense. You clearly do not understand how a GI works. How can he possibly install one when he does not have a 240v supply in his boat?
The OP said "we plug in when we are in the marina on board to trickle charge the batteries whilst we kip on board overnight running the fridge etc". So it is you are talking absolute nonsense. If he uses shore power even occasionally he needs a GI on the earth of the cable he uses.
From the things he has said it is clear that he has no fixed shorepower installation. He just uses a portable charger plugged into a shorepower lead. By chance exactly the same model of charger that I chose to show how how to test for any connection between the plug earth pin and the negative output clip.
As my reading demonstrates there is no connection, obvious anyway from the fact that as Roger observed it only has a twin flex mains cable.
Therefore no GI necessary .
Even if he had a fixed shorepower connection there would be no real need need to fit a GI if the boat is only occasionally plugged in to the shorepower supply, It is only needed by people who leave their boats connected, even if the shorepower is not in use, for prolonged periods
