Carianne
Active Member
We have our boat moored on the River Hamble... I have been doing a lot or reading about Galvanic Isolators, is it worth having one fitted? Would be grateful for any thoughts,,,,
If I may expand on this thread. I do not use shore power but on rare occasion use a genny that I sit on the pontoon and use the shore power lead. I replaced all anodes in August. In January when I was against the drying wall the annodes were completely shot. And I mean all but gone. Total genny use during that time was about 5 hours, hooked up to shorepower in a visiting port for 12 hours. Annodes correct for salt water. Yachties nearby say their annodes good for a couple of years. So what is my likely issue?
edit
The most annode wear was on the lower leg just forward of the props and the annodes in the prop hubs. Wear lessens towards transom. Props are stainless steel if that makes much difference here.
Am moored in the same area as you, just had one fitted and pleased I did, feel free to PM me any time,
I have a suspicion that the previous owner fitted one to my boat, but where would I look to find it/check?
Five hours on shorepower is not going to eat your anodes. So something else at play here, and either you are sitting in a stray current path that is routing through your bonding circuit, in which case a GI will have no affect whatsoever, or you have a leakage from your 12v DC.If I may expand on this thread. I do not use shore power but on rare occasion use a genny that I sit on the pontoon and use the shore power lead. I replaced all anodes in August. In January when I was against the drying wall the annodes were completely shot. And I mean all but gone. Total genny use during that time was about 5 hours, hooked up to shorepower in a visiting port for 12 hours. Annodes correct for salt water. Yachties nearby say their annodes good for a couple of years. So what is my likely issue?
edit
