Galvanic Isolator Position
haslemere_harry
28 Sep 2004
Hi all,
I've run a couple of searches on this but can't find an answer. I'm about to install a GI and can't work out if it absolutely has go between the inlet and first fuse box (immediately after the inlet socket in a deep cockpit locker) or if its just as effective to position it after the fuse box but before the 240v distribution panel (under the chart table). Ideally I'd like to go for the latter as there is only about 10cm of cable between the inlet and main fuse and as such will no doubt be a mighty fiddly operation.
Thanks in advance
Mark
