Galvanic isolation, the alternative?
timskip
3 Nov 2012
Does anybody know if the alternative to fitting a galvanic isolator to a steel boat moored in fresh water and hooked up to shore power is to run a good earth wire directly to an earth spike?
No its not an alternative. It would in fact increase the process of galvanic action.
A galvanic isolator actually goes in the earth line betwix boat & shore supply earth.
No but an isolation transformer would be and some say better.
Exactly - the water you are floating in is already a pretty good earth - and that's the problem - the mains earth coming in on your shore power is often quite long and not as good an earth as the water is - it's that discrepancy between the mains earth and the earth path through the water that is responsible for the erosion of your anodes.
So you are suggesting that the water is a better earth than the earth conductor in the shorepower supply.
Would it therefore be better to simply use the anodes, skin fittings, stern gear or, in the case of a metal hull, the hull itself as the earth and not connect the shorepower earth to anything at all?
That does not seem to agree with expert advice or standards such as ISO 13297
I don't think "better" is the right description - "more accurate" might be. Think about the purpose of the earth wire in a mains supply - it's there to protect you against getting electrocuted in the event of a short circuit in a piece of equipment. To do that, it simply needs to be within a few volts of the potential of the ground you are standing on and the water pipes etc. dotted around your kitchen/bathroom/living room. But it does need to be able to carry a high current - upwards of a thousand amps - at least briefly, until the fuse or circuit breaker has blown and disconnected the supply.
The earth pin in your 13a socket is connected back to an earth stake or ground plane (possibly a water pipe). The wiring will have some resistance and will be running close to other wiring, possibly picking up an induced voltage. In the marina with shorepower sockets on pontoons, the cable run back to the distribution panel may be quite long and will be shared with other boats on the same pontoon - any earth leakage in their electrical installation may push the shared earth wire a fraction of a volt above true earth potential.
The water around your boat - and the metal components in contact with it - will be at true earth potential, but the resistance to ground will be high - salt water is not a very good conductor. The fraction of a volt difference in potential between the sea water and the shorepower earth connection is what causes the anode erosion, but the water would not be able to carry the current necessary to protect you from shock or to trip out the circuit breaker.
