ColinR
A friend has a stemhead fitting that has a stainless steel strip extending down the stem, well under the waterline. This has stayed in good condition for 30 odd years, but has become eroded with what looks like galvanic corrosion over the last couple of seasons, including the screws into the GRP. Nothing seems to have changed on board. There is a hull anode at the stern that seems to be working, one on the prop shaft that he said has to be changed mid season because it erodes quite fast. One seacock seized due to age recently so he changed all of them as a precaution, and no degradation due to galvanic action was seen. The boat is plugged into shore power with the battery on charge during the season when in its berth. One thing that has changed is the neighbouring boats. I wondered if one of these might have a bad charging setup and be causing the problem? But how to diagnose the fault? Would a multi meter between the fitting and the engine block show anything? I was was going to suggest : do not plug into shore power when not in use; fit a small hull anode at the bow; bond the fitting in question to ground; cut it off short of the waterline. Any thoughts from someone who understands this better than I would be welcome. I’m going to visit the boat today so could glean more info. Thanks!
