Fusion Stereo Radio Reception = Sub Standard Crystal set!!!
Firefly211
7 Oct 2010
North Wales
Right, am a bit p****d off! Last summer I bought a very nice Fusion 600 stereo and never got round to fitting it till last weekend. I butchered the nav station panel to take it. Had to move the Glomex and Eberspacher as the Fusion needs a bit more space around it for the drop down panel. Nav panel looks like a culender. Grrr
iPod works great with excellent sound and love the zones function... but the radio is God awful...and I mean truly awful. The previous VDO Dayton unit was fine and the Fusion? Well it's cr**p. I have tried three other antennas with no improvement and as I have had it so long I don't think I can rightly take it back to supplier?
Anyone else had any problem with Fusion?
Sorry to rant - but it took me hours and I've done more harm than good!
I fitted the same model in the winter.
2 zones 4 speakers..
It seems to work just fine on Ipod, Radio and aux inputs.
I just connected it to the same ariel as the old Pioneer car radio was using.
Perhaps you have a dud set? can you return it to the supplier?
I might very well have a dud. But like I said I bought it from force4 last summer when I was on my hols and finally fitted it last week. I will give them a call and see what they can do re a replacement.
Glad yours is ok though;) Like I said the iPod side is fantastic!
So you've not had it a year. Seeing as Fusion seems to be a "premium" brand I'd say that it'll have a min of a years warranty on it. I'd be back there with it. Force 4 seem a fairly pro bunch. I can't see them not giving you an exchange, especially as you've had to cut the boat about to fit it. Give it a go, what have you got to loose?
Doesn't need a warranty. It is not fit for purpose under the Sale of Goods Act.
+1, and although SoGA needs you to report "not fit for purpose" within a reasonable time, buying something but not fitting it for a while is recognised as a valid reason for delay.
I believe "Reasonable time" is five years in England, six in Scotland.
We have a Simrad Sonic Hub which is a rebadged Fusion and the reception is fine - antenna was installed by Jeanneau with the boat and seems to be an active dipole installed under the shelf behind the bench.
Urm, sorry Fusion
I hereby offer many and complete apologies to Fusion. Clearly the instructions said to set the regional settings to Europe and not the default USA. Once I had a chat with em about my problem it was resolved in about 20 secs. Now have great reception. If only stupid people (like me) would read the bl**dy instructions!
Can someone please enlighten me as to what is so special about this 'FUSION' (radio?) that it needs to know what region it is in? Genuinely puzzled.
Edit: I am now guessing it is digitally synthesised and has pre-determined 'channels' rather than simply tuning to a given frequency ???
It's because the steps between channels in the UK and USA are different. I learned that on a CR-ROM/am/fm unit we had years ago. Once the tuners went digital, your idea is out the window.
It has nothing to do with the Fusion set itself. It has to do with "local" regulations that determine the boundaries of the FM-band and the mid-frequencies to be used by radio stations.
If I remember correct we have a bandwidth of 0.5 Mhz for every station and in the USA they have 0.6 MHz but I may be mistaken.
So every worldwide capable receiver should have these setting. Many receivers are fixed for a region.
Actually I did have a duff Fusion radio (200 series). When replaced with another one the reception improved vastly. So it does happen.
Cheers,
Arno
I have the Fusion unit and fitted mine in my Jeanneau using the 'active' antenna as well. Like the OP, my radio reception is rubbish. I just listen to the iPod (which is great).
I did (sort of) read the manual and mine is set to receive here.
