steve yates
I have a 50w panel feeding two batteries via a 10a pwm dual controller. The cable from the controller is 3mm rated for 20a.
I presume that the pos cable between each battery and the controller will need its own fuse, but should that be over 20a to match the cable or say 15a for the controller?
Ive seen often enough here that the fuse protects the cable not the eqpt, but I just want to check and whether the fuse should be 20a or bigger.
