roaringgirl
Why put a fuse between an MPPT and the battery?
I thought the same as there is a fuse in the MPPT itself. But then I think it’s maybe good practice to have a fuse very close to the batteries.…but I might be making that up…..Why put a fuse between an MPPT and the battery?
What Robih saysWhy put a fuse between an MPPT and the battery?
What Robih says
IF a fuse is fitted between the two in addition to any fuse in the controller it should be close to the battery and would be there to protect the wiring from the very high current that the battery could deliver.
However the wiring between a solar controller and the battery should be short and direct the fuse perhaps only being needed if that is not so.
