Furuno 1650 Plotter
discovery2
18 Dec 2002
Jersey
I have a Furuno 1650 plotter and although I can get a SOG readout when the GPS 'option' is selected, I am unable to get a 'speed through water' reading when the 'paddlewheel' option is selected (there is a through hull paddlewheel installed, by the way, and it does rotate freely!).
Have any other users experienced this problem, or have any suggestions that I might try?
Thanks in advance - and what a super weekend we've had - at least 'down south'!
David
discovery2
18 Dec 2002
Jersey
Thanks for your reply, and don't apologise for asking 'the obvious'!
1. I have never been able to get a reading from the paddlewheel.
2. I presume so, as the setup was installed when the boat was purchased (new!).
It is quite possible that there is a faulty connection between the paddlewheel & the plotter, and I am considering contacting the people who sold me the boat.
However, it would be less embarrassing if the solution was a simple setting that I had overlooked!
Out of interest, which make of charts do you use? I use Navionics, but I also understand another make is compatible.
David
Koeketiene
24 Sep 2003
Le Roussillon (South of France)
www.sailblogs.com
All sounds very strange to me.
What make is your log?
How is it connected to the plotter?
Charts -> I use C-Map. There are two versions of theis plotter around: one version uses Navionics or Furuno charts, the other C-Map or Furuno charts.
Should you want to sitch your set would require a software upgrade.
discovery2
18 Dec 2002
Jersey
I presume it is a Furuno log, compatible with the plotter as it was factory installed, and it is connected by a cable, terminating in a plug in the rear of the plotter. (I presume there is not a joint/connection along its length that may have a fault).
It looks as if I need to refer to the people who sold me the boat for their advice/comments.
Ref. Charts: I presumably have the version that uses Navionics/Furuno charts. The documentation also makes reference to C-Map charts and I wondered if these were compatible as well - but not so! Not a problem as the Navionics chart I have covers both sides of the whole length of the English Channel - more than enough for my cruising intentions!
Thanks for your comments
David
