eddystone
Very grateful for all the ideas and photos on this and the Sadler and Starlight owners forum. I now understand that Garmin (not sure if just this model) are more likely than others to deflect compass because of the weak magnet which latches the SD card door so as chartplotter and steering compass would both be starboard side maybe a bit too close......
Therefore, as an alternative to having it on a hinged bracket on the companionway, I thought of mounting at the chart table and making a secondary lower washboard mount. the issue then is wiring; I don't particularly want a long coil of wire stuffed somewhere around the plotter - wondered whether it would be possible to have two wiring positions so that it could be plugged in depending where it was located - how would that work at the battery/switch panel termination? Any interfacing would have to be at chart table only.
