lustyd
Thanks all, makes a bit more sense now, sorry for hijacking the thread
I guess the bearings (if any) are not made for modern day rigs.
Interesting. The Barton system is better with a high luff tension. I used a rigging screw at the drum end to get a bit more tension into it. It is suggested you can use the system instead of a forestay, but that seems a bit hopeful unless you have wire halyards.
The Wykeham Martin is also more expensive.
You can see me furling the headsail at 3 minutes 50 seconds in this vid. (If you can be arsed) Just click on the bottom bar to move to that point.
