mikeinkwazi
Any one know a company that sells Furling gear? (NOT Reefing gear!) I looked up Profurl but cannot find where to buy. Web sites like Force4 show furling but mean reefing!!!
Damn; Lakesailored again!Barton do furling gear with 2 drum sizes. You'd have to decide if the larger one was big enough. I had it on my last boat and it was very good.
you mean like this?
http://www.bartonmarine.com/images/...-FITTING-INSTRUCTIONS-2009_files/image001.jpg
And I have it on my present boat, the larger drum size which is only just large enough (I can't imagine how small your jib would need to be to use the smaller drum)
OK apart from a lack of pole in the middle can someone please explain to me the difference?
OK apart from a lack of pole in the middle can someone please explain to me the difference? Never realised there were two things!
something like this ?
Thanks for the explanation - now I feel even thicker though. If the difference is that the furling one can't reef then what advantage does it have that the OP wants over a reefing system? In the grand scheme of things the weight surely can't be the issue?
Yep. the Barton system will cost about £80 and as long as you have a wire luff that's about it.
It doesn't suffer all the halyard wrap problems that reefing systems suffer and reefed headsails aren't exactly efficient are they?
On smaller boats or cutter rigs the headsails aren't normally that big anyway, so reefing isn't as big an issue.
