boatmike
Interesting reading the Marmite opinions here as always. Frankly it is horses for courses. Most systems with a good sail cut specifically for the purpose work very well. Advantages are ease of reefing often not requiring you to leave the cockpit which can mean you have confidence to carry more sail in marginal conditions. A flat cut sail can sometimes allow beating harder to wind but this depends on several factors and can often not be so. Disadvantages are that downwind performance can be compromised due to the flatter cut sail and certainly if something does jam its a PITA so its not very common to see them on racing boats or ocean cruising boats where a jammed sail could be a real danger. That's probably an explanation for the popularity of in boom for larger boats. Don't forget that this class of boat is very seldom short handed where many of us on 25-36ft boats often are. For inshore and offshore work cruising (which is most of us I think) they are brilliant and the suggestion that they will reduce the value of a boat is ridiculous.
