Quandary
After the mast went up last month we fitted the boom, mainsail and tuned the rig, when we tried to hoist the roller furling genoa it stopped about 3/4 of the way up the foil, when we eventually got the sail down there was a 50mm. gap where the top two sections of the foil had moved away from the rest. This furler is a Profurl, the alloy foil sections are joined by cast alloy inserts about 120mm. long, they are held together by 4 grub screws, two above and two below each join, the allen key headed screws are threaded into the foil and countersunk, they seem to just grip the core by friction, no visible dimples. It has taken weeks of blood sweat and tears to sort out, the first thing was that the halyard winches are non self tailing and while two speed, pathetically weak, they managed to get me up once but refused thereafter, eventually I managed to extend a halyard and route it to a self tailing sheet winch which while slow was powerful enough. It is ***** uncomfortable hanging from a slanty forestay trying to work on it. The major problem is that all the tiny grub screws were permanently glued in to the alloy, the keys were a strange imperial size around 5/32 or something so skinny and weak, I only managed to shift one.
Eventually, using my 14 stone as a hammer I managed to persuade the sections to join together but the close fitting car refused to go past the join, in the end I finished up hand sanding each joint and lubricating, I tried silicone and ptfe sprays but in the end Pledge worked best.
In the middle of the struggle I went to look at a Facnor foil which was offered to me, similar assembly method but worse, the ss grub screw in that case had philips heads so would not accept the torque needed to shift them.
The sail is up now and hopefully will stay there until the mast comes down.
Lessons I have learned, -
before hoisting the mast
1, check that the top car runs freely the whole length of the foil.
2, lubricate the foil and get the sail up before the lubrication washes away.
3 when assembling a foil be sure to use an isolating coating on any stainless screws going in to aluminium alloy.
4 if you are lubricating a headfoil in situ it is a lot safer to go the top and work your way downwards,
All my previous furlers were Furlex and I did not encounter these problems on any of the versions I had.
