jfkal
Thanks to all the guys who sent me advise on that matter. The solution I used might be valuable for others.
Problem: Built in tank, no drain, no access hatch. Water and bacteria sludge inside.
Solution: Get access to the top of the tank. Drill a hole (11mm). Use a rigid copper tube to get down to the lowest point in the tank. Attach a hand or electrical self priming pump. Pump out water, sludge and remaining diesel. Fill in 1 liter of diesel, pump out whilst moving the copper tube sideways to sweep the bottom. Repeat process until diesel comes out clean. Tapper the hole with a 12mm taper. Screw in SS screw with washer and rubber gasket. Change filters, fill tank.
Enjoy sailing.
Enjoy sailing.
