Fuel that has been sat in the tank. Advice sought.
A_Sails_Pace
13 Jan 2022
East Coast - The Crouch
I know some people say that there is no such thing as a stupid question, though this feels a little like it might be one. That said, I'd appreciate some advice.
I am replacing my damaged fuel tank. My current (broken), half full, 90L fuel tank has been sat there whilst we've been out of the water, since October. Would the general advice be to bin it (properly of course) or to transfer to new tank? I'm worried about the recent months condensation/water build up etc - you know, just the general state of the fuel.
Can't help but feel it's a waste to get rid, but then if it's that, or potentially harming my engine then there's no real decision to be made of course.
Any advice appreciated.
Last September I returned to my boat in Greece after three years' absence. The fuel tank was 3/4 full of untreated diesel. I sampled the bottom of the tank with my Pela, found no sludge and started the engine. It ran perfectly and continued to do so, using all that tank-full.
Main point is that I know my filler cap does not allow water in, but in any case it is covered by my waterproof cockpit cover.
Many of us deliberately fill our tanks when laying up in the Autumn.
If the boat has been motionless for any length of time any water in the fuel will have separated to the bottom as diesel has a lower specific gravity (is less dense) than water. You can either drain the water from the bottom (if there is a drain) or be careful to syphon from the bottom into a waste container first, looking for water and then decant the rest of the fuel.
October 2022 ?????
If it was October 1922 - then I would say bin it !!
Fuel sits in my boat tank from end of season - Late October through to mid April .... I throw some enzyme additive in at end of season ... and at start of season ....
That's it. Nothing more. If I really feel energetic - I may get my Pela and suck up a bit of bottom to see what its like.
Because you are changing tank ..... get some clean containers - transfer that 40 - 45lts to them. Throw some enzyme based additive in ... let settle while you work on fitting new tank.
Once tank is in ... run the fuel through a filter ... leave behind any settled gunk / water .... dose with additive again and add to new tank... add fresh fuel as well with a dose of additive ... and enjoy your new tank.
How long do you think the diesel inside the tanks of the fuel berths have been lying around on winter?
If you are worried and you are around the east coast I am more than happy to collect those 45 litres for free.
Are you aware of the time frame fuel can be from Refinery to forecourt ?
It can range from weeks to many months ...
If it was me, I would bin the fuel. By the time I had removed the tank, fitted a new one, the last thing I would want to do is mess about cleaning fuel from an old tank and adding it to my new tank. Fill with fresh fuel and dose with an enzyme additive. In the grand scheme of the job, 45 litres of fuel from the old tank is not expensive to replace.
So far as I can tell... as long as the fuel hasn't separated and hasn't turned to sludge... it should be pretty good to go. Might want to top up with some fresh. If it's turned to sludge, it's going to be a headache to get out, if it's separated, remove as much water as possible and then top up with fresh.
Ha ha, thanks. What I was a little worried about was the possible constant condensation building up throughout the colder months because the tank was only half full and where there was plenty of space for moisture to gather. I think that was my thinking really.
