RAI
Is that farmer towing away his new chicken hutch?
It did surprise me that they had a tractor....it had Beneteau written on the sides...Is that farmer towing away his new chicken hutch?
Yes...good advice...never follow good advice...At last progress, just think of all the anguish you could have saved yourself if you had done this 5 months ago.
Good advice ?Yes...good advice...never follow good advice...
How is the diesel getting into that well, it looks sealed (dammed up) at both ends?
Well...that is the mystery from the beginning...for a start...that is a very shallow bowl below the engine...when it overflows the diesel pours aft a couple of inches and goes into the keel, below the shaft.How is the diesel getting into that well, it looks sealed (dammed up) at both ends?
Yes I wondered about that cable but could not decide if it went through the bulkhead or was just resting against it.It's either coming through where the cable exits directly at the bottom of the V section or more likely at the top of the V from under the tank which won't be sealed to the moulding.
However...on land the boat was a little more lower in the bow...this caused, somehow, the diesel to flow forward then fall under into the keel...kind of forward, down, back..
Don’t forget...you are seeing less than a liter...I’ve pumped out and disposed of 60 - 100 liters
We may find out by close of play...You are talking about where the diesel may accumulate but first it has to go into the space under the engine and I think that is what the question was asking, how does it get there?
Nobody can get information from the Beneteau factory of exactly what the anatomy of the boat is below the the tank and engine, not even their main dealer can prise out this information
Hopefully they will find wet diesel on the top of the moulding under the tank, does that cable go through the moulding and if it does what is under the moulding and what's the cable for?
