Seacracker
New Member
Hi everyone,
Can anyone help with this problem please?
On my boat I have a 19 gallon fuel tank which, apart from the filler tube, the fuel off take to the engine (gravity fed which is about 1 inch above the tank bottom), and... a drain point at the bottom of the tank, has no other access available what so ever.
On several occasions entering the lock at my home port Liverpool after a 'bouncy' sail, on throttling back, the engine cuts out.... not pleasant entering a crowded lock I can tell you! The engine starts again readily enough fortunately! On checking the primary fuel filter (it's an 'old' type with a removable and cleanable gauze filter), I have found loads of blackish bits in it.
Problem, how to remove these bits from the tank to avoid these problems in the future. At the moment the tank has about 15 gallons in it. The only way I can think of is to drain the tank completely and then bung some more diesel in to wash it out through the drain point.
Any thoughts, help, or advice would be most welcome.
Chris
Chris
