pvb
Fuel level sender,capacitive type,no moving,cut to length 4.6"-7", 0.5-5V output | eBay
This looks like a possibility.
What sort of gauge would you connect it to?
Going off the BEP page I linked in my previous comment, the capacitance sensor's 0-5V output is common - looks like VDO make suitable gauges, and the Lowrance NMEA converter reads it.What sort of gauge would you connect it to?
Top Google hit for "VDO 0-5V fuel gauge": SingleViu 52mm DEF level gauge. 0-5V sender required - VDO Instruments and AccessoriesI imagined the OP wanted a simple gauge, rather than putting the data into a NMEA2000 network.
Personally, I think it's simpler to have the information on the plotter than to have to drill holes for a gauge or mount it - on my B&G you can customise the right hand side of the chart display, with one or two rows of readings.
I like the BEP one you posted, as it seems very flexible - I think it can be programmed to accommodate sloping tanks?The capacitive sensor I initially posted can be ordered with either voltage or resistance indicator compatibility with the range either way and whatever range you wish.
We seem to be writing at cross purposes and I'm sorry if I've caused a misunderstanding,Yes, I like information on the NMEA2000 network, but are we sure the OP has NMEA2000?
However the capacitance sensor on eBay that @LadyInBed posted seems very affordable, and the 0.5V range seems like a standard one, that can be used with gauges from more than one manufacturer.
I couldn't immediately find pricing for the Fozmula T/LL140 capacitive gauge you posted.
PS The one I linked to Fuel level sender,capacitive type,no moving,cut to length 4.6"-7", 0.5-5V output | eBay
from the pictures on the left, it looks like it comes complete with a gauge, that's where I saw the calibration adjustment screws.
Thanks all for your inputs.
I don't have an NMEA2000 network, I am thinking fixed gauge rather than NMEA or WiFi.
In my searching I have seen analog gauges with calibration pots in.
I think Nigel Calder's book describes a non-electric pneumatic system that uses a small push button manual air pump and air pressure gauge connected via flexible tubing to the top of a tube that reaches the base of the tank (? sight tube with a sealed top).
Pumping air into this tube increases the pressure until air bubbles out of the lower end. Continued pumping does not increase the air pressure and this indicates the liquid level in the tank. A calibration card can convert air pressure to litres.
The system Calder describes has the pump and gauge mounted on a dashboard panel along with a tap to select different tanks.
