AquaholicM31
Active Member
Hi All,
Searched the forum but no luck finding an answer.
My boat has a Volvo 2003 which starts easy even in middle of winter, doesn't burn any oil, runs smoothly and quietly (well as good as a 2003 gets). So in all aspects no issues with it.
My problem comes with the exhaust which seems to contain un-burnt fuel. When the engine is tied up running in neutral it leaves a 2m circle of fuel on the surface of the water around the exhaust outlet. I assume the same happens when motoring but obviously this is difficult to see as the water is moving.
Exhaust never gives any black smoke at low or high revs but does always have a small whisp of white smoke which i think is usual for these older engines?
Any ideas what could be causing the unburnt fuel and where i should start my diagnostics...
Many thanks.
Many thanks.
