fuel gauge gasket/sealant material
mattnj
26 Jul 2007
www.red-data.co.uk
New fuel sender (stainless) to screw down to a 140l plastic tank (5 screw hole type)
What sealant should I be using that's diesel safe?
Gasket material (nitrile, cork, whatever) is far less important on a plastic tank than having the correct support from below, i.e. a rigid sandwich, screwing anything into something other than a welded boss on a plastic tank is frought with problems.
I bought a tube of Hylomar Blue for exactly the same application with a nitrile gasket but on a metal tank. The guy at the firm who sold me the new sealing kit said not to use sealent. I gave the gasket a smear of silicone grease and nothing else. 18 months later it's still fine and has never leaked.
Hylomar Blue is still unopened.
Richard
I made an access hatch about a foot square. It's bolted down onto a gasket cut from a sheet of nitrile from eBay, and there hasn't been the slightest weep from that four feet of joint. No liquid sealant involved.
What works on rigid plastic tanks and metal tanks does not necessarily work on thin bendy plastic tanks. I spent two years trying to totally seal a tank hole: in the end the solution (now several years and still so far OK) was cork/nitrile gasket, with Hylomar red round gasket and Hylomar Blue on screw threads.
Yep - I had a similar issue after removing a poorly located fuel sender. Plate with a nitrile/cork gasket and blue hylomar smeared on contact surfaces and around screw points - no leaks after a year.
