dauntlessman
Hello people,
I placed a thread a couple of weeks ago following a recent diesel engine problem. The engine lost revs/power after half an hour and eventually conked out. It was eventually put down to a sludged up tank and blocked filter with the possibility of water getting into the system.
Anyway I replaced the filter, renewed the fuel and added some diesel bug treatment. I also filled the tank to capacity with petrol station diesel to prevent condensation build up. All was well and we have just enjoyed an excellent couple of days sailing. Then about 500 yards from the mooring, exactly the same. This time the engine didn't take much time to die at around 15 seconds of choking.
I had been told that the diesel bug would break the sludge down and I may need to do another filter change after a run in. Bearing this in mind I had a few spares so grabbed a mooring and set about changing the filter again. When I took the filter out (only been in their for a few days), it looked pretty much brand new with no sludge at all. The water trap also looked completely free of water. So I have now put it all back together again (with another new filter just in case), bled the system and once again; running fine.
This is frustrating as I can't get my head around the problem. The fuel seems clean and the tank free from water. A guy in my local yard suggested another explanation which you may be able to help with. He has suggested that the fuel breather pipe may be blocked and there may be a lack of air in the tank, particularly after a half hour (or longer) run and that this could be the problem. It has been suggested that the problem would be made much worse with a full tank of fuel, hence it only taking 15 seconds to die.
On inspection of the tank (I have not had the boat long) I have come to the conclusion that there is no fuel breather at all!
Is this be the problem?
