Bandit
Estimate for a semidisplacemnt boat 14 litres per hour over normal engine cycle average assuming when cruising 400rpm below wot.
Not really. As far as we know, the OP might as well have his Sabre installed in an 80' sailboat...OK, I assumed a semi-displacement/ planing hull, do we actually know which it is yet?
But a blue note an hour, no problem, I could tear them up all day long . . . .![]()
And for around 150 quid you could go round Anglesey in a day. I usually choose to do it in 3 or 4 depending where I want to stop & play & dodge the adverse tides & the cost would be around a fiver, assuming I had to do a fair bit of motoring to catch the various tide gates. On a good trip I might not use any fuel at all. There is an annual race around the Island that takes around 24 hrs non-stop & none of them are allowed to use engines.
I can't see me switching to a true MoBo any time soon, altho I do appreciate the ability to use mine as a MoBo when it suits.
sorry, this isn't going to be too helpful to OP... but just for interest I think my Hardy is particularly good on fuel consumption, for 2012 total fuel consumption averaged 10lph... I tend to trundle along around 16knots... (yanmar 230hp)
MBM ultimate engine test: Volvo D3 220 hp
Click to enlarge:
You've got a great engine/ hull combination.
Click to enlarge:
Surely the answer to how many gallons per hour depends how much power is being produced at a particular throttle opening. WOT assume 120bhp from manufacturers figure, and for simplicity assume a flat throttle response, so half throttle would be half the BHP, or 60bhp.
Approx 1 gallon per 20HP per hour produced would seem reasonable. Thus 6pgh at 120bhp or 3gph at 60bhp.
Don't see speed or hull type enters the equation to any great extent. Just my opinion.
I am staggered to understand how what appear to be experienced boaters totally fail to understand the very basics of propulsion.
I assumed this stuff is taught at basic powerboat training levels.
Leave it out. Powerboat training is about tides and hitting or should I say not hitting the hard bits.
Anything in the direction you are showing is done at engineering level.
Mind you most of us power boaters can open bottles and cans with the best of them
Just to throw another spanner in the works, my boat has a 135hp Lehman and I normally run around 1700-1800revs at that she burns less that 2 gallons per hour.
Tom.
Hmmm...Let me see, I'm going to guess 5 kts.![]()
Tom.
Tom,
How is it throwing a spanner in the works???
Say GB 32 is around 14 tonnes with LWL of 29ft??
Your Lehman Super 135 is exact same motor as Sabre 120C.
GB hull form is slightly unusual, flat sections, displacement, but capable a being bit harder than hull speed, my hull speed SWAG would be about 8.5 knots. Setting throttle at 1,800 rpm gives you POTENTIAL power of around 95 hp. However based on 14 tonnes and cruise speed of 7 knots your propeller is only DEMANDING about 55hp, therefore 2 gallons per hour sounds perfectly feasable consumption.
Not for the first time, let me try again!.................Propellers move boats engines merely turn them.
Think of your throttle as cruise control on a car or truck. With properly matched propller rated speed is the only point where propeller demand curves match. Take a look at ANY marine engine data sheet, you will see two curves, one showing full power, the other is the propeller demand curve.
Just to keep it simple, we set throttle(cruise control) on say a SINGLE Sabre 120C at 2,000 rpm. Engine has the POTENTIAL from full load curve to produce 103 hp ' 2,000 rpm, however looking at the propeller load curve based on exponent of 3, propeller is demanding tad less 65 hp..............Where has the 38 hp gone? Quite simply the engine is not producing it! When you set throttle to 2,000 rpm and handed responsibility from your hand to the engine governor to adjust the amout of fuel required to achieve 2,000 rpm.
Yes, hull type does matter because propeller demand is characteristic of hull shape, displacement hulls come in around 3, planing hulls typically 2.6/2.7.
Tom,.....Say GB 32 is around 14 tonnes.............
Thick.Call me thick, but I don't see your argument.
