Tranona
Back home from my sailing trip.
Here is my performance graph:
Speed is more or less linear since for a fixed pitch propellor engine revs to speed should be linear. Fuel consumption increases dramatically at higher revs - I'll bow to other wisdom that it is a cube curve.
Consumption is a function of power used over time, not distance travelled, either through the water or over the ground. Distance travelled is affected by sea conditions and tide stream.
You can correlate the two (time and distance) in flat conditions and no tide but as soon as you introduce adverse weather conditions speed falls for given power, and if you have tidal streams for or against speed over the ground (and therefore distance travelled) will increase or decrease.
