jfm
OK, if it does then fine and I would eat all of my words. But how does it know? Who has calibrated it and set up the true physical zero? How did they do it?Why, of course it knows where the (physical) zero is.
(When I argued about this after your post #11, we were not talking about your boat. You were advising others to use a trick, so we were talking about boats generally, not yours. But I do not mind whether we discuss this by reference to your boat or to boats in general)
We may be at crossed purposes. Sorry if not explaining it well. I meant that if you sync your engines by ear to within 15rpm (or by a reference grade tacho), and drive in a perfect straight line, and then you set that as your zero on the a/pilot, you would be all wrong if, unbeknown to you, one prop happened to be longer than the other. On older boats (pre 3D prop scanners) props can easily be say 3% different length. They're only sand cast. You know yours are perfectly matched? How? Scanned?I seriously struggle to understand how you can think that this could happen with one prop longer than the other
