MarkJohnson12345
Terrific day out, sun and some sailing until the wind died.
Motor started several times during the day.
Moored up my pontoon this evening, the next door neighbour very kindly gave me a beer, and we nattered for 10 minutes or so.
Suddenly my boat engine just started up, all by itself!!! (Bukh)
A mad dash to the cabin, (not spilling the beer I have to say), the engine compartment was full of electriccy type smoke.
I tried to turn the engine off with the key, by turning it anticlockwise. Nothing happened.
So we now have to stop the diesel engine.
In the meantime the battery monitor is having fits, with all sorts of warning sounds coming from it, and I could see the voltage of the main battery dropping, 6 volts was the last time I saw it.
I switched off the main diesel flow thingy, but nothing happened other than the motor continuing to run. I took off the diesel tube from the tank to the primsary filter, eventually took off the main filter. The engine still took 2 to three minutes to run out of fuel.
My neighbor then said I could have stopped the engine by opening the decompressors. Thats something I have learnt tonight.
The wire from the fuel pump solenoid is fried.
There seems to several wires in the loom that are also fried.
Having stopped the engine, I switched off the batteries. I did not want to do that whilst the engine was running as I thought that would damage the alternator.
To see if there was any life anywhere I did switch on the mains battery charger. I switched on one battery, and the engine tried to start again.
So to make it all safe, I have disconected both batteries, and disconnected the mains.
The main battery voltage is les than a volt, the engine battery which was isolated is fully charged at 12.9 odd volts.
WTF went on??
I guess I was lucky that it happenend at the end of the day, and not when I was 10 miles away at anchor off the Gower coast.
I intend to get the local marine engineers to sort it, but would dearly love to know what went wrong.
Despite the potential cost, I can see a funny side to it, watch out if your flippin diesel decides to start it self, and sort out a strategy for stopping a diesel when the solenoid F****s up.
WTF went on??
