jfkal
This time no questions but sharing of experience.
Was struggling with my fridge for a while (barely went below 10 degrees Centigrade even after hours). Then I looked at the problem systematically.
1. Wire size has to be adequate otherwise the battery saver kicks in too early reducing the runtime of the compressor.
2. Install a auxiliary battery close to the fridge (through splitting diode).
3. The fan usually installed at the compressor is inadequate if the unit is placed in a confined space. Use an additonal fan to force the warm air out from whereever the compressor sits.
4. Insulation of the cold box inadeqate. Increase by adding closed-cell foam sheets on each and every wall as well as lid and bottom.
5. Drain too large (cool air "falls" down through the drain sucking warm air in through the lid gaps)
6. Poor circulation in the cold box allows the evaporator to freeze up stalling the cooling process. Installed two PC type fans forcing circulation top-down through the (O type ) evaporator.
Result? -7 Degrees centigrade within 15 minutes
Now the question: How can I prevent the beer from freezing up?????
