geem
Water cooled certainly helps in the UK as the water is so cold. Very little energy benefit here in the Caribbean. Sea water temperatures are often higher than air temperatures at night. Sea temperature in Antigua has been 26degC all winter but cabin temperature has been 21-23 degC at night. I liked our water cooled fridge on our last boat but we chose not to go that route with the current fridge knowing we would be in the Caribbean.We happily run ours 24/7. It is water cooled with a hull mounted sintered bronze cooling plate outside the hull. Compressor is separate from the cabinet allowing extra insulation all around the cabinet. About half the power consumption of the same volume air cooled unit it replaced. Standard Danfoss compressor but not noisy enough to disturb sleep.
