mick
I need to replace the hose that connects the deck filler to the fresh water tank. Any reason why I can’t use plain white sanitation hose?
If you are going to drink the water it should be food grade hose.
https://www.sheridanmarine.com/search/query/drinking+water+hose
Only three of the hoses we found were suitable for drinking water, or marked as ‘food grade’.
This isn’t an issue if you’re just looking to wash your boat down, but to fill a water tank it’s worth spending the extra money for a food-safe hose. Some plastics, often present in garden hosepipes, can leach bisphenol A (or BPA) used in the manufacturing process into the water, which is a potential health risk.
Manufacturers recommend running the hose through before placing it in your tank (a good idea anyway), to clear any nasties from the pipe. A food-safe hose is a wise investment!
http://www.pbo.co.uk/gear/6-compact-freshwater-hoses-24600
This is about hose pipes from the marina tap to the boat, not the hose from the filler to the tank.
Tranona
I've re-read the article and I'm sure I am not mistaken:
"It’s long been the case that marinas across the Channel don’t supply hoses, but in the past few years marinas in the UK have been removing theirs at an alarming rate too. That means that if you want fresh water, either to wash down your boat or fill your water tanks, you will need to carry your own hose".
If it is recommended that "food grade" hose be used from the filling station to the boat then surely all hoses for potable water on the boat should be "food grade" too?
There are all sorts of toxic substances in our households/environment which are known to be health hazards we don't need to add such substances as BPA or lead.
Clive
