nonitoo
Being a bit careful with my boat and engine I note that the maintenance book says that the engine should be flushed with fresh water after every use.
How is this possible if the boat is marina based ? Do others perform this task after each use, if so, how do you do it as my outdrive water intake is always below the surface even when raised.
Do I just sit and watch it rot away ?
(Cummins Mercruiser 2.8 ltr diesel with Bravo 3 outdrive)
