fresh v salt..does it matter
capel679
26 May 2004
ipswich
i am about to take ownership of a grp hulled boat. she has been in fresh water all her life and i wondered if now going into salt water is likely to have any effect on the hull...
i know about annodes. just the grp hull is my concern.
ta in advance
gjgm
14 Mar 2002
London
modern grp hulls will probably last forever! Think the main reason for sellers saying fresh water is that its alot less corrosive on fittings,engines, etc etc- nothing to do with the grp.
pvb
UK East Coast
Only a beneficial effect...
I imagine you're wondering about osmosis. Although there's still some debate about osmosis, most people seem to agree that there's more risk of osmosis in fresh water than in salt water. Higher water temperature (often found in fresh water areas) can also accelerate osmosis. So your hull should be fine!
smeaks
31 Aug 2003
tyneside
I think the only difference must be good. I believe Osmosis is the movement of water moecules from a solution of low concentrate to one that is more cocentrate. Thus the risk of initiating osmosis in fresh water must be greater than in salt water where the osmotic potentiol is reduced......phew what a mouthfull!
Doibg the same myself next season after 2 yrs in freshwater.. fingers crossed!
steve
jleaworthy
20 May 2002
Essex
I think it's true to say that most GRP hulls show signs of osmosis if they have been in fresh water for some years - you should see the hire fleet on Loch Ness. If you have no osmosis now, you have nothing to worry about concerning the hull. Engine, if raw water cooled, and skin fittings could be another matter depending om material/design.
