Fire99
Evening gang,
My 'Snappie' Has a traveller rail bolted on the transom with a 22mm (or imperial equiv.) nut at each end 'glassed over' on the underside of the transom.
One end was so loose, the nut had unwound itself half a dozen turns, so was relatively easy to remove (once the glassfibre was chipped away that was over the nut),
The other end however, won't budge. The nut will move in the GRP (by moving the rail with the other end free) but it appears to have welded itself to the thread. ('Galling' perhaps? ) Even with a socket and fairly decent leverage it just wants to twist the rail. I've read somewhere about heating the thread to help free the nut. Would you suggest this?
Many thanks,
Nick
Many thanks,
Nick
