anderson
does anyone have any info on an F L Marine 12v windlass it has 2 drums for warping no chain gibsy only 1 drum turns the other does not stripping it down the shaft that does not turn is in 2 parts an inner and outer the inner turns the outer does not their is a lever on the side which is on a worm shaft if you pull it towards you it will lock up I think this might be a brake but it does not stop the drum turning the other side with the inner and outer shaft does not have key in the inner shaft but has a key in the outer shaft to turn the drum .see photos
