PetiteFleur
A couple of years ago whilst checking the engine after launch, I suddenly noticed water pouring from the rear of the heat exchanger - quickly solved with new end cap bolts etc.
So that I was aware of such a catastrophic event in the future I fitted an Engine Bilge water alarm - a simple battery operated alarm which when the two wires of the sensor cable contacted water the alarm and flashing light goes off.
Well, a couple of weeks ago we went off with 5 crew & dog to a local hostelry, had to motor-sail as had problems with the genoa furling gear(another story), it was a bit lumpy and the alarm went off after about an hour and we had several litres of water sloshing about under the engine. Electric Bilge pump pumped it dry ok. Since then been trying the source of the definitely seawater.
Anyway a friend and I went out again up river last week, one steering and the other trying to spot any leak. Then under full throttle, water slowly appeared in the bilge around the bilge pump and the penny dropped - under full throttle the stern squatted and water slurped down the bilge pump outlet... Have now fitted a large loop in the pump hose run at the stern.
