Daydream believer
I would re configure the kicker attachment differently to that proposed by others
First think laterally & apply the stress in a different place
Make a "U shaped piece & rivet it to the SIDES of the boom, not the underside
I am sure you should be able to find something in dinghy chandlers if you cannot find anything for a "U"
You could in fact have 2 seperate strips bent so that they met in the middle
If you are really in trouble & want a repair to last for a while until you can get a replacement boom then buy a length of builders strap ( BAT strap approx 32 * 3mm thick -do not need 5mm th) from Travis Perkins for under a fiver. It is galvanised & already drilled. Put a 250 mm or so piece on each side & crank them inwards so they meet & join them where they pick up the vang with a shackle. try to get the fixing a bit further along the boom than the crack so you do not emphasise the stress point
The important part is to get the angle correct. To do this put the boom level & then mark the angle using a piece of string from the kicker attachment point to the point where you want it to meet the boom
Try to get the rivets in the upper " compression" sides of the boom rather than the lower " tension" position
There are so many old dumped wrecks about these days, a second hand boom should be obtainable given a few weeks to find one
