fouling seagulls.
tonyg
6 Aug 2001
S.W.Ireland
This probably isn't the first mention of this subject, and although my boat seems not to suffer from the problem, our fruit-cage does, or did. Here's the answer:- fold an area of thick black polythene into a triangular cushion shape measuring about 30cm on each side. stick onto it two white eyes made from bostik tape or similar. These should be lozenge-shaped, about 25mm long, with a black pupil slit(vertical, like typical predator) of felt tip marker. Suspend by thread from convenient point, and lo! Not a bird in sight. Looks quite menacing. Possibly would work also if made pyramid-shaped with eyes on each facet(?) and simply set onto cabin-top. Hope it's not that frightening that birds bowels are loosened though.
Cheers Tony G.
hlb
RIP
Any Pub Lancashire or Wales
On the other hand I have an electric fence that runs off torch batteries. It's very efective with Harry so expect it would flatten a sea gull!!
<hr width=100% size=1> <font color=blue>No one can force me to come here.<font color=red> I'm a volunteer!!.<font color=blue>
Haydn
castaway
31 Dec 2001
Solent
uk.groups.yahoo.com
Maybe they stay away cause they think yr motorsailing!
Seriously though I do suffer froim this problem so will give this a try as back up to the usual use of CDs
Can you clarify.... is it hung so it swings like a delta wing?? or does it hang from a corner?
Thanks Nick.
<A target="_blank" HREF=http://www.yachtsite.co.uk/fairweather>http://www.yachtsite.co.uk/fairweather</A>
ccscott49
7 Sep 2001
I've seen lots of owls on boats, doesn't seem to stop em'. Maybe this will, if it works, it will be the saviour of many a boat owner.
markdj
31 Jul 2002
Strangford Lough, Northern Ireland
www.stronge.org.uk
Talking of owls, our's worked and kept away most of the seabirds, but between the hours of Friday 11pm and Saturday 5:30pm 27th and 28th June, someone stole our owl!!! When we arrived at the boat (it's on a mooring) the rear cover was not on properly and we didn't immediately notice the missing owl til later yesterday evening. If anyone is offered an owl in the Strangford Lough, Northern Ireland area please contact me asap. The owl goes by the name of "Auwlie".
I'm not joking...
<hr width=100% size=1>Mobile UK Weather
<A target="_blank" HREF=http://www.stronge.org.uk>http://www.stronge.org.uk</A>
markdj
31 Jul 2002
www.stronge.org.uk
Prestart engine heater for 1 minute then turn key. Repeat for 2nd engine. Drop mooring ropes and push forward on morse gear controls. Push forward on throttle levers and away she goes. Use helm to turn port and starboard to avoid other boats...
<A target="_blank" HREF=http://www.jasc.com>http://www.jasc.com</A> Click on the animation shop.
Be sure and join the...
<hr width=100% size=1>Princess Owners Club
<A target="_blank" HREF=http://surf.to/princessownersclub>http://surf.to/princessownersclub</A>
a bsa .22 meteor is pretty good at loosening their bowels
s
B
bob_tyler
Why not just do your part in reducing the seagull population?
Take a long piece of thin string. Tie a piece of bacon rind on one end and the other end to the top of the mast attached to a halyard. Get under way so it flies out astern. One seagull will swallow it and promptly eject the rind at the other end. Another seagull will swallow it and so on until you have a squadron of gulls following in line ahead, all flapping madly!!! What you do with them then is your problem!!!
markdj
31 Jul 2002
www.stronge.org.uk
Since our owl has gone we have had starfish legs, bits of crabs and things on the front deck !!!!!!
THE OWL DEFINITELY WORKED and we will be getting another one asap.
