Ford Sabre212C
Venatrix
1 Aug 2012
Hi. I am looking for either a dead or alive Sabre212C.
I have a project boat that has a 212C and a second engine that is a Dover Block marinised by I believe Hendy Power products.
My aim is to have a pair of matched 212C engines.
At the very least I need.
Heat exchanger/header tank.
Amot Valve assembly.
Watercooled turbo charger.
Pipework I can get copied in Stainless from my existing 212C.
Please advise if anybody can help.
Thanks in advance.
Thanks in advance.
I have moved this quest for parts a bit further forward and I have obtained a couple of Amot Thermostats from a supporter of this Forum, Thanks Omega Man.
I can narrow this down a bit further. The Bowman header tank that I need is a FH420 but it needs to be with the horse shoe shaped end clamp fittings rather than the end caps with a bolt that runs through the stack from end to the other.
If anyone can help that would be great. I can email a picture to anyone that needs clarification of what is required.
Many thanks.
Ian
Can anyone advise if a company out there somewhere makes the silicon hoses in the same shade of red that Sabre used. Lots of bright reds and blues available on the internet. The Sabre Red was a bit more subdued.
If you contact Stephen Atkins at Mermaid in Poole 01202-677776, he'll be able to help you with anything Sabre Ford.
Best regards
Jon
