ripvan1
I use a small chef's torch when it's cold, probably get H&S'd now for admitting to that.
Hmm, my MD22 is DIRECT injection and starts easily without the glow plugs!
Written by an engineer with 55 years of ICE experience!
S
S
S
Thornycroft T108 is a marinised BMC 1.8
Beware it will still spark if totally or partially shorted to earth. The only reliable method is to compare resistances individually or as a set after calculating the resistance in parallel. Note this a different calculation than series resistance which is the sum of all.
The spark is the whole point - no spark the current isn't going to earth and the glow plug is useless - if it sparks its good ,
You appear not to fully understand this. My point that having seen a plug that when removed from the engine was physically burnt out but the end of the internal element was welded to the casing thus presenting a circuit and capable of producing a spark but useless for task.
wow - did you get any pictures.
Just another day at the "office". Do not see anything earth shattering to record a picture of a broken glow plug.
I've got a Volvo Penta MD1, it has no glow plugs and uses excess fuel to start from cold so I'm guessing direct injection but I wouldn't describe it as new tech being made in 1967.
