dur
Very many apologies for this very long winded first post but I am desperate to find a solution so I though I would try and include the whole story so far.
I have spent thousands on a new engine installation and with hindsight I really should have rebuilt the Volvo. So apart from feeling like a complete fool I am so disappointed and fed up with the whole business,
My earlier post on this is here: http://www.ybw.com/forums/showthread.php?394215-Knocking-prop-shaft
Background:
Old Volvo MD11C had to be replaced. The prop is offset to starboard and so I wanted to retain the left hand prop as the boat already pulls strongly to port and I imagine it would be worse still with a right hand prop due to paddle wheel effect. Also the prop is feathering so expensive to replace. So the prop and tube was retained and pretty much everything else replaced.
The boat - 1929 shoal draft Maurice Griffiths "Wind Song" , 24' waterline 2'6" with the plate up and 8'6" beam. 5 tonnes.
The new setup is:
Beta 25 and TMC60 gearbox with oil cooler (so rated to run in reverse direction to give ahead propulsion). 2.45:1 going ahead and 2.83:1 going astern
Left hand (anti-clockwise) Darglow JF 15 x 12 feathering prop on new 1" stainless steel shaft, new cutless bearing, traditional fixed stuffing box with greaser with new packing. Installed by experienced Beta agent.
The idle speed is (now) about 1000 rpm when warmed up
Gearbox to shaft coupling intially R&D now Centaflex type M 127
On first trial the engine made a horrible knocking noise at tickover speeds when in gear (That position you get to when you click into gear either ahead or astern and you would use for slow manoevering or even gentle motor sailing). This occured both going ahead and astern though slightly worse going ahead.
If the throttle lever is pushed over the next spring position the engine runs at 1500 rpm and the knocking smooths out.
Beta's first advice was to increase the tickover to 910 rpm which I did but as soon as it is in gear the revs drop to about 700 rpm anyway and it knocks. If I hold the lever against the spring to say 1100 rpm it mostly smooths out- just a little rough.
There is no noise in neutral and if the shaft is disconnected there is no knocking noise in either forward or reverse
Alignment checked using the R&D feeler gauge technique. It was in limits but I got it a little closer still.
Didn't make any difference.
I rang Darglow props who immediately said that they would suspect torsionally vibration (caused by the new engine having virtually no flywheel). The low speed torsional vibration causes the pressure on the feathering baldes to fluctuate sufficiently they lift and then go back onto the stops causing the knocking. They said the same can happen with a fixed prop but the knock is transfered to the gearbox instead.
R&D coupling replaced by Centaflex Type M 127 coupling.
Immediately smooth and quiet in in reverse but still as noisy going ahead.
Other things looked at/considered:
Engine mounting studs - apparently earlier Beta studs could stick through the mounts and hit the bearers. I used dividers to compare the length of stud above the top of the mount and they are all the same. I concluded this is probably a red herring.
Another comment was that if the gearbox has a cone type selector then it could be more susceptible to low speed torsional vibration running in reverse (i.e boat going ahead) as the helical gear is trying to drive the cone out rather than in. I don't know how the TMC60 works etc. so not sure about this.
Beta tried to say the prop is too big but as they sized a 20 hp with the existing prop and I subsequently went for a 25 hp on the installers advice this doesn't make sense.
Checked again with Darglow and and they advised that they would have suggested a 15 x 11½” prop so the 15 x 12 is close enough as to make no difference.
Beta suggested that maybe the engine is quite high on its mounting studs and that it might be worth putting a packer under mounting feet. I think on the front of the engine any packer would have to be about 15 - 20 mm. I imagine this would slightly reduce the amount of movement of engine on its relatively soft mounts. I watched the engine and noticed that in reverse the engine (now) hardly moves and is very steady and relatively smooth. In ahead the engine moves about a lot more and at least some of this movement is transferred to the prop shaft.
So packing the feet might help but it doesn't feel like this is the actual problem - otherwise why did the Centaflex get rid of the problem in reverse. Makes me wonder about using stiffer engine mounts
Another thought - could the knocking be the prop shaft hitting the gearbox - but I don’t think that it could be because it is the same propshaft installed with the R and D coupling so it is a little bit too short for the Centa insert - maybe 20 or 25 mm short of the front of the insert. It certainly doesn’t stick through the front of the insert. Also why did it make the same knock with the R&D coupling.
The gearing is lower in reverse but only by about 15% so 800 rpm ahead ought to be the same as 700 pm in reverse. But it still knocks at 900 rpm going ahead.
Other thoughts - would a PRM150 have been better as it doesn't matter which way it runs. I did ask about one several times when Beta were specing the engine but they discounted it in favour of the TMC60.
I have spoken / emailed Beta many times and they have been pretty helpful but I don't think they know what to do next and have started asking the same questions we have been through several times before. I spoke to Centa and they spoke about a softer drive plate between engine and gearbox but Beta are baulking at that and I believe it is a tricky install with not much space. Darglow were great too. In fact everyone has been very helpful and sympathetic but I am getting nowhere. If it were a new car engine I would have taken it back - but its not of course.
If somebody can come up with a solution (that I can afford) I would be very very grateful and there would be a bottle of Scotch in it somewhere I am sure!
Background:
The new setup is:
