foot rest while helming. ?
UK-WOOZY
7 Feb 2015
medway river
Hi all. does anyone have any ideas on what could go here by the transom for helming. could do with something to push our feet against when sailing especially when the boats heeling. not sure what though.
thank you
Carbon fibre arranged in a hollow triangular shape (similar to toblerone chocolate). Also handy for storing sailing instruction mid-race.
i meant something already available and affordable.
thanks anyway.
I use the boat for cruising and the occasional race like the thames trafalgar. and im on a budget.
i thought about a metal tool case. bolt it to the floor. could keep the fuel can in it and use to push our feet against. dunno
How about a length of wood, say 3x2", removeable, resting in a wooden slot at the stern and companionway. Height to suit. I have a similar setup on my boat for crew in the cockpit, I have wheel steering, just slots around wheel pedestal and in wooden slot at companionway.
I think you should experiment with a wooden box perhaps in the middle under the tiller. critical dimensions are the width hence distance from your seat to the box to suit you and likewise the height of the box. Once you ahve sorted the dimensions then you can make or buy a stainless stel rail to put your feet on probably one each side of the correct height or make a box or shape that suits you. Yes lopy top might be more comfortable.
You might also like to fit a webbing strap to fit over your feet for added security.
Just for interest my little boat has wide gunwhales. Beng tender as son as the wind comes up the helmsman is sitting up on the gunwahle with feet on the seat. I have webbing straps on the inner edge of the seat full length for hemsman and crew to tuck feet under for more security. If I am not up on the gunwhale then I don't need feet rest. Perhaps becuase I have improved rudder ballance making tiller loads a lot lighter. good luck olewill
good ideas thank you.
my rudder is pretty well balance. but when the boat leans it would be good to have something to push againsts with the feet to stop one self from falling onto the other side. it can lean up to 35 degrees easily
That's the problem with wide-arsed more modern designs. On a nice older boat you can put your feet on the lockertop opposite.
On my first trials car we had an alloy plate on brackets for the passenger to brace against
Reinforced at the back with brackets
As you will want it available from both sides you could just make a folded sheet, attached to the floor.
Which is what I have (on the right) in the current car.
You can get alloy tread plate cu to size from any decent fabrication shop. probably about £5 for what you want. You can cut it easily yourself with a jigsaw using a coarse blade, Spray the cut line with WD40 or Plusgas to prevent snatching.
Phil's (lakesailor) ideas for a folded piramid shape would be fine if the distance from your seat to the centre is the distance you want to be comfortable when helming. It may be however if you have short legs that you need the rest closer to you. ie wider than just folded to a narrow vee. It also might be that you prefer a rest less vertical ie I imagine about 45 degrees might be better than the tight vee shape. Hence my proposal to build a test fixture in wood like a box to get the dimensions you want. or you may be able to guess with a helper. Definitely the finished product could well be out of ali plate as Phil suggests. Next step is to incorporate padding and even elctric foot warming. good luck olewill
thats genious
i dont have grating on the floor though. mine is just a 22ft yacht. with tiller steering.
did you buy that stool premade or did you make it?
How about some webbing like what you find in some dingies (not that I've been in one for over 40 years)? You should be able to rig a lenght from the transom to where those winches are. Cheap and you can remove it easily when not needed.
