Houleaux
I've just fitted a 2 blade Varifold folding prop.
The boat went back into the water today and I started her up and engaged forward and reverse with her on her berth to make sure everything was working ok.
I did this from tickover and, whilst reverse engaged quietly, there was quite a loud clonk each time I engaged forward. (The boat was being driven in both forward and reverse, so the blades were opening ok).
I realise that the blades will open faster when in forward gear and therefore hit the stops with more force, but is this clonk normal?
The prop is quite big - 17" x 14 - and the blades are therefore correspondingly heavy.
My first thought was that the engine, gearbox and shaft were all moving forward as the prop took up drive in forwarrd gear and that maybe I'd fitted my rope cutter (a Stripper) too near the P bracket so it was hammering into that, but on reflection I think that that would be more of a tap than a clonk. I can't detect any fore and aft movement of the shaft when the gears are engaged.
The clonk happens a short while after the shaft starts turning, so I don't think it can have anything to do with the gearbox.
I'll ring the manufacturers in the morning for advice, but I wondered if anyone could put my mind at rest in the interim?! I really don't want to have to have the boat lifted again.....
Thanks.
Thanks.
