Dougal
I know this subject came up a little while ago, but i'm after more info...
If I'm using a 12volt FM receiver designed for a car, as I suspect are many/most.
Should I be using 50 or 75 Ohm coax?
When I simply joined a long (approx 2.5mtrs) piece of electrical wire (unshielded) to the end of the coax run, and dumped it in a 'snotty heap' over my davits, the reception was good to excellent, only getting interference when mains battery charger (or neighbours wind gen) running.
I then followed instructions from here and other places; cutting the unshielded wire to the specified length, and running vertically. The reception is now shite;-) so I'm trying a few (cheap) alternatives.
Would I be correct to assume that physically connecting the coax to rigging has no value (or worse) ?
Would a car radio antenna need grounding at source, like the car bodywork?
What about 'stubb antennas' - any good?
All input most welcome.
EDIT: In France and would LOVE to get BBC Radio4 but its only available on LW. Is there any way to increase LW reception, or is that an internal winding?
