Fly by wire remote issue
Bellissima
31 Dec 2025
Hi all
Can anyone help please ?
I have a 1999 Azimut 42 with a fly by wire throttle issue.
When I put the port throttle into reverse the remote bleeps and flashes red. This stops when it’s put back in neutral or forward gear is engaged although bleep and light comes back when you select reverse again. Despite the bleep and light everything works fine for a few shifts into forward and reverse then it stops engaging forward or reverse altogether. Only way to get it to work again is to kill the port engine and re-start it then the all of the above happens all over again.
Any thoughts clever people ?
Graham
I had a similar issue with one engine going into neutral and refusing ro go forward or reverse. Only cleared by turning off ignition which reset the controls. Resolved with new cable as resistance was generating an error condition and forced neutral.
Thank you really helpful. When you say cable do you mean electrical cable or shift cable ?
The ZF Command Module in the engine room takes the signal from the electronic throttles. Then there are mechanical cables that then control the engine and transmission. So it could be one of the cables in the engine room?
