Shearwater
..............is there a little man with a magnet inside my Raytheon ST1000 ? If not can you explain how it knows which way its pointing?
It's kind of amazing that they're still making them with olde worlde compasses in. Surely it would be cheaper for them to pop a smart phone compass onto a daughter board? And then when the 'o' rung fails and falls into the bottom of the case it wouldn't jam the compass.
At least one older kind of flux gate or flux valve compass uses a pair of coils on iron cores mounted at right angles to one another. Often gimballed to keep them aprrox level. Each coil is treaded separately. The coil is periodically (400hertz) energised to saturate the core then current is removed allowing the magnetic field to collapse in the core. The resultant current coming out of the coil with field collapsing is peculiar to the amount and direction of the earths magnetic field. ie aids or opposes the collapse to a measurable degree. Comparison of the wave shape of the 2 coils can give direction for the earht's magnetic field. A processor then operates a dial autopilot or in the case of aircraft slowly aligns a gyro card to give a gyro stabilised compass heading. That is one kind but often remote compasses just have a magnetic needle swinging on a card whose direction is detected optically.
More modern types might use "Hall Effect" semicondcutor sensors where conductivity is varied by applied magnetic field. A few of these set up for great sensitivity are likely used in tiny hand held devices.
good luck olewill
GPS antennae are becoming so accurate and cheap now that better still would be a GPS compass such as this (http://www.panbo.com/archives/2014/...ps_compass_true_heading_comes_to_the_usa.html).
I might fit one once the prices come down a bit. Get rid of crappy magnetic bearings entirely![]()
Can you explain all that again, in really simple english pls.
