davidmh
I need to flush out the cold water pipes on the yacht. There are three flexible plastic hoses which run from the tank to the the 3 outlets. All 3 are teed together at the tank end. At each outlet there is a foot operated pump such as the whale flipper pump. I need to get a good volume of water through it and the idea I had was to connect a water supply hose to the tank end of the pipe and hope that the water pressure will keep the pump valves open to allow the water to pass through the pump. Will this work or have I missed something about the valves in the simple foot operated pumps.
The forums knowledge will I am sure know the answers to this one.
Regards
David MH
Regards
David MH
