pagoda
We have a venerable 2HP Yam (Pre -cdi) which in the past was run in a dustbin of freshwater after use in the sea. That was mainly when the engine was used for pottering around the nearby coasts in fine weather. A dustbin was ideal because the engine is permanently in gear - no reverse, and the prop always turns.
As the engine has been promoted to push a new small inflatable tender, we don't have that luxury of vast containers of fresh water at sea.
The input to the water pump consists of 3 or 4 small holes in a row - just under the cavitation plate -which makes the use of almost any "water - flush- muff" impossible. No space!
Has anybody else got a solution? I still see many of these little 2HP 2 strokes sitting on aft rails, so they're going strong yet.
After about 2 years of non- use in my father's shed before I decided to use the engine again, I extracted about half a cupful of congealed salty deposits from the exhaust manifold and cylinder block casting, before I could get water going through again. I really don't want to have to do that regularly on a pontoon or peir somewhere!
It might be possible to fit a 1/8 or 1/4 NPT fitting to the lower leg - and temporarily block the the original intake while feeding fresh water into the new fitting.
Solutions appreciated.
Graeme
Graeme
